BlockWindowManagement Method
The BlockWindowManagement method blocks the window management and prevents thereby new windows from being blocked.
    AdminFunctions.BlockWindowManagement()
    The AdminFunctions object is only available in the escape menu.
    The following example prevents new windows from being blocked.
    AdminFunctions.BlockWindowManagement();
