AdminFunctions Object
The AdminFunctions object provides administrative functions.
The following table lists the members provided by the AdminFunctions object.
This object is only available in the escape menu.
The following example blocks window management temporarily in oder to start the windows explorer.
AdminFunctions.BlockWindowManagement();
SiteKiosk.ExternalApps.RunElevated('C:\WINDOWS\explorer.exe')
document.onclose = function() {
AdminFunctions.UnblockWindowManagement();
