CheckRestrictedPassword Method
The CheckRestrictedPassword method checks whether a given string matches the correct restricted SiteKiosk user account password.
    AdminFunctions.CheckRestrictedPassword(password)
    password String value that specifies the
    password to be checked.
    Returns a Boolean value that is true if the given password is correct.
    The AdminFunctions object is only available in the escape menu.
    The following example allows to quit SiteKiosk if a correct password is entered.
    <input type="password" id="pwd" />
    <input type="button" value="Quit" id="quitbtn" />
    <script type="text/javascript">
    quitbtn.onclick = function() {
      if (AdminFunctions.CheckRestrictedPassword(pwd.value))
        SiteKiosk.Quit();
      else
        alert('Incorrect password.');
    </script>
