BasePnPID Property
The BasePnPID property contains the recorder's manufacturer, product ID, and revision information.
    [str=] SiteKiosk.CDRecording.RecorderList.Item(index).BasePnPID
    String that contains the information.
    This string can be used to consistently identify a specific class of device by make and model. It can be used by applications to customize their behavior according to the specific recorder type.
    The following example shows the manufacturer, product ID, and revision information of the first existing recorder in an alert window.
    alert(SiteKiosk.CDRecording.RecorderList.Item(1).BasePnPID);
