CDRecorder Object
The CDRecorder object provides information about a CD recorder.
    The following table lists the members provided by the CDRecorder object.
    Members
    Properties Description
    BasePnPID Manufacturer, product ID, and revision information.
    CanRewrite If the recorder is able to rewrite a CD-RW.
    MaxWriteSpeed Maximum write speed.
    Path Path to the device within the operating system.
    ProductID Product ID of the recorder.
    RecorderGUID The recorder's globally unique identifier (GUID).
    Revision Recorder revision.
    VendorID ID of the vendor.
    This object is returned by the Item method. Use the CDRecorder object to receive information about a CD recorder.
    The following example shows the maximum write speed of an available CD recorder in an alert window.
    if (SiteKiosk.CDRecording.RecorderList.Count > 0)
       alert(SiteKiosk.CDRecording.RecorderList.Item(1).MaxWriteSpeed);
    else
       alert("Could not find a CD recorder");
