CanRewrite Property
The CanRewrite property indicates whether the recorder is able to rewrite a CD-RW.
    [bool=] SiteKiosk.CDRecording.RecorderList.Item(index).CanRewrite
    Boolean value that retrieves the RW status.
    The following example determines whether the first existing recorder is able to rewrite CD-RW's and shows it in an alert window.
    alert(SiteKiosk.CDRecording.RecorderList.Item(1).CanRewrite);
