MaxWriteSpeed Property
The MaxWriteSpeed property contains the maximum write speed.
    [long=] SiteKiosk.CDRecording.RecorderList.Item(index).MaxWriteSpeed
    Long value that retrieves the speed.
    The following example shows the maximum write speed of the first existing recorder in an alert window.
    alert(SiteKiosk.CDRecording.RecorderList.Item(1).MaxWriteSpeed);
