Path Property
The Path property contains the path to the device within the operating system.
    [str=] SiteKiosk.CDRecording.RecorderList.Item(index).Path
    String that retrieves the path.
    This path should be used in conjunction with the display name to completely identify an available disc recorder. It is of the form "\Device\CdRomX".
    The following example displays the path to the first existing recorder within the operating system.
    alert(SiteKiosk.CDRecording.RecorderList.Item(1).Path);
