ProductID Property
The ProductID property contains the product ID of the recorder.
[long=] SiteKiosk.CDRecording.RecorderList.Item(index).ProductID
Long value that retrieves the product ID.
The following example shows the product ID of the first existing recorder in an alert window.
alert(SiteKiosk.CDRecording.RecorderList.Item(1).ProductID);
