RecorderGUID Property
The RecorderGUID property contains the recorder's globally unique identifier (GUID).
    [str=] SiteKiosk.CDRecording.RecorderList.Item(index).RecorderGUID
    String that retrieves the GUID.
    The following example shows the GUID of the first existing recorder in an alert window.
    alert(SiteKiosk.CDRecording.RecorderList.Item(1).RecorderGUID);
