Revision Property
The Revision property contains the revision of the recorder.
    [long=] SiteKiosk.CDRecording.RecorderList.Item(index).Revision
    Long value that retrieves the revision.
    The following example shows the revision of the first existing recorder in an alert window.
    alert(SiteKiosk.CDRecording.RecorderList.Item(1).Revision);
