VendorID Property
The VendorID property contains the recorder's vendor ID.
[long=] SiteKiosk.CDRecording.RecorderList.Item(index).VendorID
Long value that retrieves the vendor ID.
The following example shows the vendor ID of the first existing recorder in an alert window.
alert(SiteKiosk.CDRecording.RecorderList.Item(1).VendorID);
