RecorderState Property
The RecorderState property indicates whether the active recorder is ready.
[bool=] SiteKiosk.CDRecording.RecorderState
Boolean value that retrieves the ready status.
The following example determines whether the active recorder is ready and shows it in an alert window.
alert(SiteKiosk.CDRecording.RecorderState);
