UpdateRecorderState Method
The UpdateRecorderState method updates the recorder state.
    SiteKiosk.CDRecording.UpdateRecorderState()
    Use the RecorderState property to receive the current recorder state.
    The following example updates the recorder state and shows it in an alert window.
    SiteKiosk.CDRecording.UpdateRecorderState();
    alert(SiteKiosk.CDRecording.RecorderState);
