RecordMode Property
The RecordMode property contains the record mode.
    SiteKiosk.CDRecording.RecordMode [=long]
    Long value that specifies or retrieves the mode.
    Possible record modes are:
    0 : Data / Joliet
    1 : Audio / Redbook
    If this property is 1, the files of the AudioFiles collection will be recorded.
    If it is 0, the files of the RootDirectory object will be recorded.
    The following example shows the current record mode in an alert window.
    alert(SiteKiosk.CDRecording.RecordMode);
