RootDirectory Object
The RootDirectory object controls the root directory of the CD.
The following table lists the members provided by the RootDirectory object.
This object is available through the object CDRecording.
Use the RootDirectory object to retrieve information about the CD root directory or to create a new directory.
The following example burns a complete directory to a data CD.
if (SiteKiosk.CDRecording.RecorderState)
SiteKiosk.CDRecording.RecordMode = 0;
SiteKiosk.CDRecording.Title = "My new CD";
SiteKiosk.CDRecording.RootDirectory.Import("c:/dir");
SiteKiosk.CDRecording.Record(false, true);
