HasText Method
The HasText method returns whether the clipboard contains text.
[bool=] SiteKiosk.Clipboard.HasText()
Returns a boolean value that indicates whether the clipboard contains text.
The following example determines whether the clipboard contains text and shows it in an alert window.
if (SiteKiosk.Clipboard.HasText())
alert("Clipboard contains text");
} else alert("Clipboard contains no text");
