Clipboard Object
The Clipboard object provides access to the clipboard.
The following table lists the members provided by the Clipboard object.
Properties |
Description |
Text |
Contains the clipboard text. |
Methods |
Description |
Clear |
Deletes the clipboard content. |
HasText |
Returns whether the clipboard contains text. |
This object is available through the main object SiteKiosk.
Use the Clipboard object to read or write the clipboard text.
Thge following example determines whether the clipboard contains text and shows it in an alert window.
if (SiteKiosk.Clipboard.HasText())
alert(SiteKiosk.Clipboard.Text);
} else alert("Clipboard contains no text");
