Text Property
The Text property contains the current clipboard text.
    SiteKiosk.Clipboard.Text [=str]
    String that specifies or retrieves the clipboard text.
    The following example displays the clipboard text, changes it and displays it again.
    alert(SiteKiosk.Clipboard.Text);
    SiteKiosk.Clipboard.Text = "Clipboard text changed";
