BrowseForFolder Method
The BrowseForFolder method displays a 'browse for folder' dialog.
[filename=] SiteCafe.UserInterface.CommonDialogs.
BrowseForFolder(parentwin, rfolder, title, flags)
parentwin |
Handle to the parent window. |
rfolder |
String that specifies the root folder. |
title |
String that specifies the title. |
flags |
Long value that specifies the flags (BROWSEINFO). |
Returns a String that contains the absolute path of the saved file.
The default flags (if flags is null) are:
BIF_EDITBOX, BIF_NEWDIALOGSTYLE, BIF_RETURNFSANCESTORS, BIF_RETURNONLYFSDIRS, BIF_USENEWUI
The following example displays a 'browse for folder' dialog and shows the selected filename in an alert window.
dialogObj = SiteCafe.UserInterface.CommonDialogs;
alert(dialogObj.BrowseForFolder(0, "c:/", "title", 0));
