CommonDialogs Object
The CommonDialogs object provides standard dialogs.
    The following table lists the members provided by the CommonDialogs object.
    Members
    Methods Description
    BrowseForFolder Displays a 'browse for folder' dialog.
    OpenFileDialog Displays an 'open file' dialog.
    SaveFileDialog Displays a 'save file' dialog.
    This object is available through the UserInterface object. Use the CommonDialogs object to display file and folder dialogs.
    The following example displays an 'open file' dialog and shows the selected filename in an alert window.
    dialogObj = SiteCafe.UserInterface.CommonDialogs;
    alert(dialogObj.OpenFileDialog(0, "*.exe", "c:/dir"));
