BrowseForFolder Method
The BrowseForFolder method displays a 'browse for folder' dialog.
    [filename=] SiteKiosk.SiteKioskUI.CommonDialogs.
                BrowseForFolder(parentwin, rfolder, title, flags)
    parentwin Handle to the parent window.
    rfolder String that specifies the root folder.
    title String that specifies the title.
    flags Long value that specifies the flags (BROWSEINFO ulFlags).
    Returns a String that contains the absolute path of the saved file.
    The default flags (if flags is null) are:
    BIF_EDITBOX, BIF_NEWDIALOGSTYLE, BIF_RETURNFSANCESTORS, BIF_RETURNONLYFSDIRS, BIF_USENEWUI
    The following example displays a 'browse for folder' dialog and shows the selected filename in an alert window.
    dialogObj = SiteKiosk.SiteKioskUI.CommonDialogs;
    alert(dialogObj.BrowseForFolder(0, "c:/", "title", 0));
