CommonDialogs Object
The CommonDialogs object provides standard dialogs.
The following table lists the members provided by the CommonDialogs object.
This object is available through the SiteKioskUI object.
Use the CommonDialogs object to display file and folder dialogs.
The following example displays a 'open file' dialog and shows the selected filename in an alert window.
dialogObj = SiteKiosk.SiteKioskUI.CommonDialogs;
alert(dialogObj.OpenFileDialog(0, "*.exe", "c:/dir"));
