OpenFileDialog Method
The OpenFileDialog method displays an 'open file' dialog.
[filename=] SiteCafe.UserInterface.CommonDialogs.
OpenFileDialog(parentwin, filter, dir)
parentwin |
Handle to the parent window. |
filter |
String that specifies the file filter. |
dir |
String that specifies the initial directory. |
Returns a String that contains the absolute path of the selected file.
The following example displays a 'open file' dialog and shows the selected filename in an alert window.
dialogObj = SiteCafe.UserInterface.CommonDialogs;
alert(dialogObj.OpenFileDialog(0, "*.exe", "c:/dir"));
