OnTransactionBegin Event
Fires when a transaction begins.
SiteKiosk.Plugins("SiteCash").Devices("CreditCard").
OnTransactionBegin = handler
ID |
Long value that contains the ID of the transaction. |
obj |
CreditCardInfo object that contains information about the card. |
cur |
Currency value that contains the amount to transact. |
Use the CurrencyFormatter object for currency functionality.
The following example shows the transaction value in an alert window when a transaction begins.
creditcard = SiteKiosk.Plugins("SiteCash").Devices("CreditCard");
creditcard.OnTransactionBegin = OnTransactionBegin;
function OnTransactionBegin(id, ccardinfo, amount)
alert("Transaction value: " + amount);
