CurrencyFormatter Object
The CurrencyFormatter object contains the SiteCash currency environment.
The following table lists the members provided by the CurrencyFormatter object.
This object is returned by the SiteCash.CreateCurrencyFormatter or SiteCafe.CreateCurrencyFormatter method.
Use the CurrencyFormatter object to determine or change the way you want the currency information to be displayed.
The following example shows the currency symbol in an alert window.
mycfm = SiteKiosk.Plugins("SiteCash").CreateCurrencyFormatter();
alert(mycfm.CurrencySymbol);
