Format Method
The Format method transforms a long value into the usual currency notation.
[str=] CurrencyFormatter.Format(currency, bool)
currency |
Currency value to format. |
bool |
Boolean value that specifies if the currency symbol should be included. |
Returns a String that contains the formatted value.
The following example formats a currency value in such a way that it includes a comma and the currency symbol.
mycfm = SiteKiosk.Plugins("SiteCash").CreateCurrencyFormatter();
mycurrency = 10;
alert(mycfm.Format(mycurrency, 1));
