SymPlacement Property
The SymPlacement property contains the position of the currency symbol.
[long=] CurrencyFormatter.SymPlacement
Long value that retrieves the symbol position.
The position is a value between 0 and 3, the numbering is the same as the enumeration of the possible positions in the SiteKiosk configuration file.
The following example shows the position of the currency symbol in an alert window.
mycfm = SiteKiosk.Plugins("SiteCash").CreateCurrencyFormatter();
alert(mycfm.SymPlacement);
