CustomerData Object
The CustomerData object provides information about the owner of the card.
    The following table lists the members provided by the CustomerData object.
    Members
    Methods Description
    GetData Reads user information from the smartcard.
    SetData Writes user information to the smartcard.
    This object is available through the object ACOS. Use the CustomerData object to set or receive information about the SmartCard owner.
    The following example shows all available user data in an alert window when a card has been inserted.
    smartcard = SiteKiosk.Plugins("SiteCash").Devices("ACOS");
    smartcard.OnUserDataReady = OnUserDataReady;
    function OnUserDataReady(id, index, data)
       alert(id + " " + index + " " + data);
