CheckForIntranet Property
The CheckForIntranet property indicates whether to check for an existing connection to a web server before establishing a new connection.
    [bool=] SiteKiosk.Dialup.CheckForIntranet
    Boolean value that retrieves the check status.
    The following example determines whether to check for an existing connection before establishing a new connection and shows it in an alert window.
    alert(SiteKiosk.Dialup.CheckForIntranet);
