Dialup Object
The Dialup object permits to establish a dial-up Internet connection.
The following table lists the members provided by the Dialup object.
This object is available through the main object SiteKiosk.
Use the Dialup object to connect to the Internet or to request the current connection status.
The following example reads the current connection status and shows it in an alert window.
alert(SiteKiosk.Dialup.ConnectionStatus);
