ConnectionStatus Property
The ConnectionStatus property contains the current connection status.
    [bool=] SiteKiosk.Dialup.ConnectionStatus
    Boolean value that retrieves the connection status.
    The following example reads the current connection status and shows it in an alert window.
    alert(SiteKiosk.Dialup.ConnectionStatus);
