ConnectionTryMax Property
The ConnectionTryMax property contains the number of times SiteKiosk will try to connect.
[long=] SiteKiosk.Dialup.ConnectionTryMax
Long value that retrieves the number of times.
The following example shows in an alert window how often SiteKiosk will try to connect.
alert(SiteKiosk.Dialup.ConnectionTryMax);
