ErrorText Property
The ErrorText property contains the error message if an error occurred.
[str=] SiteKiosk.Dialup.ErrorText
String that retrieves the error message.
The following example tries to connect and shows the error message if an error occurres.
SiteKiosk.Dialup.OnError = OnError;
function OnError()
alert(SiteKiosk.Dialup.ErrorText);
myconn = SiteKiosk.Dialup.RequestConnection("reason", false, true);
