HangupOnShutdown Property
The HangupOnShutdown property indicates if the dialup connection is to be closed after SiteKiosk has been terminated.
SiteKiosk.Dialup.HangupOnShutdown [=bool]
Boolean value that specifies or retrieves the hangup status.
The following example defines that the dialup connection stays alive after SiteKiosk has been terminated.
SiteKiosk.Dialup.HangupOnShutdown = false;
