KeepAliveAction Method
The KeepAliveAction method resets the internal idle timer counter.
SiteKiosk.Dialup.KeepAliveAction()
The idle time after which the connection will be closed automatically can be configured in the SiteKiosk configuration.
The following example resets the idle time.
SiteKiosk.Dialup.KeepAliveAction();
