MaxIdleTime Property
The MaxIdleTime property contains the maximum idle time before disconnecting.
[long=] SiteKiosk.Dialup.MaxIdleTime
Long value that retrieves the maximum idle time.
The following example shows the maximum idle time in an alert window.
alert(SiteKiosk.Dialup.MaxIdleTime);
