OnConnect Event
Fires when a dial-up connection is established.
SiteKiosk.Dialup.OnConnect = handler
The following example shows an alert window when a connection is established.
<div id="cstatus">Connect now</div>
SiteKiosk.Dialup.OnConnect = OnConnect;
function OnConnect()
cstatus.innerHTML = "Connection established.";
