OnDisconnect Event
Fires when a dial-up connection is closed.
SiteKiosk.Dialup.OnDisconnect = handler
The following example shows an alert window when a dial-up connection is closed.
<div id="cstatus">Disconnect now</div>
SiteKiosk.Dialup.OnDisconnect = OnDisconnect;
function OnDisconnect()
cstatus.innerHTML = "Connection closed.";
