OnError Event
Fires if an error occurred.
SiteKiosk.Dialup.OnError = handler
The following example shows the error text if an error occurres.
<div id="estatus">Connect now</div>
SiteKiosk.Dialup.OnError = OnError;
function OnError()
estatus.innerHTML = SiteKiosk.Dialup.ErrorText;
