OnProgress Event
Fires while SiteKiosk tries to establish a connection to the Internet.
SiteKiosk.Dialup.OnProgress = handler
Fires after each step of progression until 100 percent are reached and a connection is established.
The following example connects to the Internet and shows the progress.
<div id="progress"></div>
SiteKiosk.Dialup.OnProgress = OnProgress;
function OnProgress()
var p = SiteKiosk.Dialup.ProgressPercent;
var t = SiteKiosk.Dialup.DisplayText;
progress.innerHTML = p + " % / " + t;
myconn = SiteKiosk.Dialup.RequestConnection("reason", false, true);
