DisplayText Property
The DisplayText property contains the description of the application.
    [str=] SiteKiosk.ExternalApps.Item(index).DisplayText
    String that retrieves the description.
    The following example shows the description of the first application that was configured.
    alert(SiteKiosk.ExternalApps.Item(1).DisplayText);
