ExternalAppInfo Object
The ExternalAppInfo object contains information about a configured application.
The following table lists the members provided by the ExternalAppInfo object.
Properties |
Description |
DisplayText |
Description of the application. |
Path |
Full path of the application. |
ProcessID |
Process id of the application. |
Running |
If the application is currently running. |
Methods |
Description |
Kill |
Kills the application. |
Run |
Runs the application. |
RunSync |
Runs the application and returns the exit code. |
This object is returned by the Item method.
Use the ExternalAppInfo object to receive the description of a configured application or to run it.
The following example shows the description of the first application.
alert(SiteKiosk.ExternalApps.Item(1).DisplayText);
