Path Property
The Path property contains the full path of the application.
    [str=] SiteKiosk.ExternalApps.Item(index).Path
    String that retrieves the full path.
    The following example shows the full path of the first application that was configured.
    alert(SiteKiosk.ExternalApps.Item(1).Path);
