ProcessID Property
The ProcessID property contains the applications process id.
    [long=] SiteKiosk.ExternalApps.Item(index).ProcessID
    Long value that retrieves the process id.
    The following example shows the ProcessID property in an alert window.
    alert(SiteKiosk.ExternalApps.Item(1).ProcessID);
