Run Method
The Run method runs the application.
SiteKiosk.ExternalApps.Item(index).Run(bool)
bool |
Boolean value that specifies if SiteKiosk is to check first if this application is already running. |
The following example runs the application configured first.
SiteKiosk.ExternalApps.Item(1).Run(false);
