Running Property
The Running property indicates if the application is currently running.
[bool=] SiteKiosk.ExternalApps.Item(index).Running
Boolean value that retrieves the running status.
The following example shows the Running property in an alert window.
alert(SiteKiosk.ExternalApps.Item(1).Running);
