RunSync Method
The RunSync method runs the application and returns an exit code after closing it.
    [long] = SiteKiosk.ExternalApps.Item(index).RunSync(timeout)
    timeout Long value that specifies the timeout period.
    Returns a Long value containing the exit code.
    Setting the timeout parameter to -1 means that there is an infinite period of time.
    If a time out occurres an exception will be thrown.
    External applications can be configured in the SiteKiosk configuration.
    The following example runs the application configured first and shows an alert window if a time out occurres.
    try
       myexitcode = SiteKiosk.ExternalApps.Item(1).RunSync(20);
    catch(e)
       alert("Time out");
