ConfigFilename Property
The ConfigFilename property contains the full path to the favorites configuration file.
    [str=] SiteKiosk.Favorites.ConfigFilename
    String that retrieves the full path.
    The following example shows the full path to the favorites configuration file in an alert window.
    alert(SiteKiosk.Favorites.ConfigFilename);
