Favorites Object
The Favorites object provides the current favorites settings and is also a collection of the favorites.
The following table lists the members provided by the Favorites object.
Properties |
Description |
AddingAllowed |
If adding favorites is allowed. |
ConfigFilename |
Full path to the favorites config file. |
Enabled |
If favorites are enabled. |
SaveOnClose |
If favorites should be saved when SiteKiosk is closed. |
Count |
The number of existing favorites. |
Methods |
Description |
Item |
Returns one item of the collection. |
This object is available through the main object SiteKiosk.
Use the Favorites object to receive the favorites settings.
The following example determines whether favorites are enabled and shows it in an alert window.
alert(SiteKiosk.Favorites.Enabled);
